I picked up this Neslab immersion cooler a while back with the intention of converting it to direct die; I finally got around to doing it and after a couple of rebuilds with different evaps, gasses, etc., it's finally done. This is a nice simple system that does an excellent job and is much easier than a complete build from scratch, mainly because you have a case with the compressor and condensor allready mounted. Cases are hard to make unless you go with wood or something similar and that is heavy and not all that professional looking.
Anyway, this thing has a 1/4hp compressor, 8"X8" dual row condensor, 9' .031 cap tube, and a cap in cap evap I made using a Maze4 gpu block for the base.
This is the unit as I got it... it had a long rubber hose for suction liine with no insulation and a 6" long evap meant to be immersed in what ever liquid was being cooled.
I removed everything but the compressor and condensor and rerouted all the tubing. I used a fexible stainless steel suction line that exits out the opposite side of the original, This pic is the first incarnation and was using a Chilly1 evap and gassed with propane. The propane reached -50c under vacuum but was not very good at holding temps, especially with my 950es Presler
Recently I got some r507 and ended up redoing the whole system with new tubing, new filter dryer, and went to a cap in cap evap that I wanted to test. I flushed the old mineral oil out of the compressor and refilled it with POE for the r507. Temps are better and it reached -53c under vaccum, tuned with load it gets -48c evap and idles in windows at -38c with the 950 @ 1.44v and 4.8ghz, under load with both cores loaded 100% it will hold -27 - -28c. This is very good for a 1/4hp system IMO
Here is the finished unit, nothing fancy, but it does the job...
