phantom 630 case modding
_tucker_
basically ive chopped out the drive bays at the top of my case and removed all hdd cages as ive no need for either
and i want to build something in its place to house more ssds and a couple of temp gauges and possibly going to a 2 loop water cool set up and run identical res and pumps (the same ones i already have now)
do you think the 2 way set up will work? or fit i should say.
where the drive bay was on the far right as there might be a rather large void im going to possibly put another gtx 280 black ice rad so it mounts to the 140mm holes on the bottom right but the other side of the 200mm fan that's at the front if that makes sense.
theese are pis of where im currently at and in a min ill post up what ive seen somebody else do that will be similar
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
This is sort of what i want except without the drive bays there and in there place will be a new rad hopefully
Complete with butterflies in the front? I mean, I'm not one to judge, but damn that's gay. :D
