Phanteks Revolt X
Sky15
I have 1000W version of this PSU and just bought a 4090, but I also bought a Seasonic 12vhpwr cable.
From what I've read, phanteks is basically a rebranded Seasonic. If so would the adapater work?
From what I remember the 1200 and 1000 revolt x are built by Seasonic but I can't say if the adapter is keyed the same as their focus platinum units. You should probably contact either Phanteks or Seasonic to make sure. Even if the PSU side looks the same, it may not be wired the same.
Hi guys,
While we usually do not provide support for third-party brand, I can still give you a hint for Phanteks: https://cablemod.com/compatibility/
Check Phanteks and see the compatible set. Same as the one used by... Seasonic for your PSU. So, our 12VHPWR cable will be compatible.
Now for our 12VHPWR cable:
  1. If you are in the US/Canada (or one of the country that is available for this cable to be shipped to): https://www.btosinte.com/Seasonic-12VHPWR-Modular-Cable-SS-12VHPWR.htm
  2. In Europe, we are a bit late for the stock, so we recommend to check for some Cablemod instead for now:
    https://eustore.cablemod.com/product/cablemod-basics-rt-series-12vhpwr-pci-e-cable-for-asus-and-seasonic/
    https://eustore.cablemod.com/product/cablemod-rt-series-pro-modmesh-sleeved-12vhpwr-pci-e-cable-for-asus-and-seasonic/
    https://eustore.cablemod.com/product/cablemod-rt-series-pro-modflex-sleeved-12vhpwr-pci-e-cable-for-asus-and-seasonic/
  3. If you are not in North America / Europe, drop us an email to see if we can help: https://seasonic.com/contact-us
Thanks!
Perfect! I bought the cable from btosinte hoping it work.
Hi mate, I've got the revolt sfx and also interested in the Seasonic 12VHPWR cable. Just wonder is the cable working well on your Phanteks PSU?
