Phanteks PH-F140 Case Fan
HardOCP News
[H] News
If you need a new 140mm case fan or two, the fellas over at OCC say the Phanteks PH-F140 is a solid choice.
Based on the specifications given by Phanteks, the fans seemed to be just as awesome as they were said to be. The idles and the loads both were very impressive across the board and all @4.4Ghz. Even with the XP using the QSA adapter the temperatures were all so far down I wouldn't even be afraid to up the voltage and the clock speed for a faster overclock.
