Phanteks Launches The Enthoo Pro
HardOCP News
[H] News
Staying true to the Enthoo Series, Phanteks releases the Enthoo Pro. Phanteks’ Enthoo Pro aimed at budget-conscious enthusiasts that doesn’t want to compromise on features for price. Unleash unlimited possiblities with the budgetfriendly Enthoo Pro. To reduce cost while maintaining design, the Enthoo Pro comes with a textured exterior finish that mimics the appearance of brushed aluminum. Two models of the Enthoo Pro are available. PH-ES614P will include a window side panel that allows users to showcase their watercooling or aircooling setup. And for users that want the visiblity of their setup hidden, the PHES614PC comes with a non-window side panel.
The Enthoo Pro’s removable chassis allows more flexibiltiy for the end user. Instead of using rivets the Enthoo Pro now features screws that can be easily removed. This allows the chassis to be taken apart for easy access and modding. Embracing many features from the Enthoo Primo, both models will have mulitple radiator support, removable ssd bracket, closed HDD panel, and velcro cable management. Options for upgrading is possible with the vast array of accessories designed for the Enthoo Series.
