Phanteks Eclipse P400A case question
RareAir23
Hi all. This will be an easy one for anyone who owns the case in the subject: on the case's built in fan controller when you have your fans connected to it and you power on the machine for the first time what is the default speed setting of the fans? Is it low, medium or high? It doesn't give that info in the case's manuals. Thanks in advance for the answer. Out!
pendragon1
i would assume that it just remembers what you had it at before, otherwise it would be a PITA to have to change/reset it every time you power up.
