Vengance_01
- Dec 23, 2001
I am looking for something small, low powered but with some room to grow to support high end fiber connections as my new house is served by Frontier aka Verizon Fios in the future. They only offer 150/150 max atm, but I can see them adding more speeds as charter rolls out the new 3.1 cable standard. I stumbled on this company who makes Atom based SOC boards the size of Raspberry-PI that use 5V power adapters.
Currently looking at the following:
z8350,2GB LPDDR3,16GB eMMC for 99$
http://up-shop.org/up-boards/2-up-board-2gb-16-gb-emmc-memory.html
Now the above setup only has 1GB Ethernet, so for the WAN side I was going to use a USB 3.0 gigabit Ethernet based on ASIX AX88179 chipset which is on the FreeBSD HWC list. Also the USB 3.0 has its on dedicated lane. Throw in a cheap 7$ case and 10$ 5V 4A power adapter and I got a pretty nice tiny PFsense firewall that can grow in performance for about 150$ ish shipped
The second setup is also from this company but they have a board that's about the same size but includes dual GBe Nics and has a Apollo Lake M Intel Celeron 2C 2.4 GHz N3350 2GB LPDDR4, 32GB eMMC and more USB 3.0 ports etc... for 149$
http://up-shop.org/up-boards/92-up-squared-celeron-duo-core-2gb-memory32gb-emmc.html
Add a case for 14$ and 15-20$ for a 6A 5V PSU for a total of close to 200$ish
I feel the first is a better deal despite being an atom chip you get 4 cores and since freeBSD is SMP aware, this processor would give overall performance for a PFsense router where as the Celeron would be better as a general PC or other device that's more dependent on memory bandwidth or single threaded performance.
I thought about getting this before I found these UP-Boards, but they seem to be older atom platforms and use 12V power bricks which will draw more power.
https://www.amazon.com/Firewall-Mic...rd_wg=RRNEd&psc=1&refRID=MWFDVJJENX6ADPB2P0XF
In closing just looking for some thoughts. I will not be doing any VLANs, I have my trendnet 8 port GB switch which will be my LAN side and my AP"s will be Unifi base A/C in wall units. I know I could just get a Unifi router-X but I have heard to many horror stories and I want to be able to do Snort, VPN, A/V scanning etc... plus I want something fun I can play with and tweak.
EDIT**
To throw a wrench into this, should I just get the Routerboard HeX POE which give me support to power my 2 in-wall POE based Unifi A/C AP's and based on a another thread here can handle a gigabit connection without issues.
EDIT**
