DlStreamnet
- Mar 10, 2005
Hi guys, I do have another thread regarding this but thought I'd clear it up to get some more targeted help if possible. Background:
Intel Xeon 1230
DQ67SW
16GB non-ECC
2x 10/100/1000CT Intel NIC's
Running PfSense, 32bit or 64bit, Monowall 32bit - I hit a brick wall of 10Mbit when connecting over PPPoE to my VDSL modem. I am not sure if it's WAN or LAN.
This happens on e1000, VMXNET1 and VMXNET2 Enhanced. It also happens when I use VT-D passthrough for the WAN interface.
Downloading a 1GB file from thinkbroadband gives 2198kBps (does this indicate 2MB a second? - if so it could mean my problem is LAN based...??)
vSwith configuration:
I have tried:
- VT-D passthrough of the WAN NIC - same.
- vSwitch PPPoE - same.
- Monowall and PfSense 32/64bit - same.
- Setting auto negotiate OR forcing 100MB Full Duplex on the PPPoE vSwitch
Running out of ideas. I did try and set up Smoothwall SP3 yesterday but I couldn't get it to connect using PPPoE/DHCP hostname option 60 (which the freeBSD things do perfectly).
Help?!
Intel Xeon 1230
DQ67SW
16GB non-ECC
I have tried:
Help?!
