PROJ-004-HP
CD-R KING LCD PROJECTOR 1800 LUMENS
RATING- 4.5 STARS
Personal Experience
Our company had used many kinds of projectors, but when one of our previous projector broke down I was the one assigned to buy a new one. My budget was to not spend over Php10000, so I decided to check Cd-r king if they have an affordable and reliable projector on which they always have. I purchased the model PROJ-004-HP that costs Php9990, I have been testing this projector for the past few days and I have nothing but good things to say about it. It works without fail, I especially liked the design very compact and lightweight and a convenient menu. The picture was sharp and the sound (though not that powerful) was very clear, It`s also capable of 4:3 and 16:9 aspect ratio exactly what it claims. The 1800 lumens are right on the money, the brightness allows you to enjoy the image in a dimmed room or darker, As with all projectors, the image will always be better the darker the room. It has all the inputs you can ask for and so far all worked well. I was also surprised it included all options of cables, for the price I would have expected to have to order them separately. It also has cool features like power zoom, focus and lens shift which is really easy to achieve because of the projector`s user-friendly functions. The main thing about this projector it has 6000-8000 hours of lamp life, and it seems to be really durable, described for what it actually does. Normally a projector like this would really hurt your wallet, so its a very good buy.
Package Contents:
LCD Projector - 1
Remote control - 1
VGA Cable - 1
RCA Audio Video jack cable -1
Power cable – 1
Manual - 1
