Perpendicular M2 Slot
ecmaster76
Any reason all the M2 slots are parallel to the mainboard?
Seems like turning them perpendicular would help the cooling significantly.
Just put it on the spot where there is usually an X1 slot above the main x16 slot
On a lot of boards now it creates a dead zone under the GPU where two more PCIE slots would normally fit
Granted one of those is usually covered by a two slot GPU cooler but not always and the one below that would normally be useable especially for a low profile NIC that wont block the GPU air flow.
It has to be secured somehow, you can't just have it hanging free. It's possible if somebody makes an appropriate holder. (But this would prevent installation in a low-profile case).
Yeah, I think a holder would be easy enough
Even perpendicular it would be shorter than a low profile expansion card so for most cases that would be fine
Some boards do have them vertical like that, Asus does a few. The thing is, it looks dumb and boards are all about aesthetics today. It also takes a special bracket to hold it with enough pressure on the contacts.
With the abundance of PCIe expansion slots on high end boards, ample amount of onboard peripherals, and with triple GPU setups having horrible diminishing returns (or simply no longer supported), why not use one of the PCIe slots to pull this off?
They could make a special PCIe adapter card that several M2 cards fit into (NVME work off PCIe anyways), or they could simply have a bunch of vertical M2 slots in the PCIe area that have a special bracket to attach to the PCIe slots on the case.
-edit-
They already make these:
https://www.newegg.com/Product/Product.aspx?Item=9SIA4M53SS6788
I've surprised someone hasn't stepped it up a little bit by incorporating the necessary circuitry to put several M2 drives on 1 card. If they have, I haven't seen one yet.
I'm talking about having the long side of the M2 ssd perpendicular to the mainboard (similar to the orientation of RAM DIMMs but with the socket on the end instead of the bottom)
The current PCIe adaptors are nice but the M2 device is still be parallel to the adaptor card, constricting airflow. That is a good point that multiple SSDs could be fit in on one - effectively a storage riser.
