Permanant snow on 9800?
Andrew87
My 9800 has been overclocked for a few months, see sig - very small overclock. Anyway I put the Core upto 395 and was watching some movies with Windows Media Player, fell asleep, woke up 3 hours later and shutdown the pc (no snow at this point).
This morning when I was watching some more movies I noticed after about 20mins there was some snow, so I restored the clock and mem to stock, ran Pixel Shader 2.0 in 3DMark and there was still snow, no big deal I thought the card was just a little hot.
So I come back now, about 9hours later, start the computer from a cold boot with stock clocks, run Pixel Shader 2.0 and there is still snow, my case isn't even hot :/.
This is happened once before but when I tried the PC the next day it had fixed itself, somehow. I don't think the GPU is still hot after 9hours. I did install the new nVidia IDE drivers and Sounddrivers for nForce2 which seem to be buggy, I should uninstall the IDE drivers really, may get round to it later, that's the only real reason I can think of the snow still coming up, it happened at around the same time, 395 on the clock shouldn't cause damage, Windows Media Player isn't exactly an intensive 3D app.
My VGA Silencer should come tomorrow, do you think this will fix the problem if it still persists? Natually I'll be aiming for higher clocks though :).
I'm gonna upgrade my Cats to 4.3 from 4.2 now, I hope this isn't permanent, I guess I'm just hoping for some reassurance that the GPU can stay hot for so long or something, and that it'll sort itself out :)
Thanks for reading.
Phew, I found a solution (I hope)! Here's what I did step-by-step:
1) Flash A7N8X Deluxe from UBER1007 BIOS to standard ASUS 1007 BIOS
2) Uninstall RadClocker
3) Uninstall all nVidia nForce 2 Drivers
4) Uninstall ATi Catalyst 4.2
5) Restart
6) Enter BIOS and setup like before
* Changed AGP Frequency from Auto to 66Mhz
7) Install nVidia nForce 2 Drivers
* With 4.31 Soundstorm Drivers
* Using nVidia's modified IDE Driver, not the SW IDE or new 2.5 ATA
8) Install ATi Catalyst 4.2
9) Restart
10) Edit ATi Control Panel settings and put sliders to lowest setting
11) Run 3DMark2003 Pixel Shader 2.0 test
Result - no snow :).
I have no idea why this worked but it did :). I'm gonna try again with high quality and AA/AF this time and post back.
EDIT
Forget all my above post, putting the sliders all the way to the right with AA and AF on resulted in SNOW, agh.....
artifacts/distortion, when things overheat.
I dont know if low voltages can result in snow but I know i need a new PSU and my computer gets madd streeks every 4 or 5 boots
Snow is where you get small white blocks in the display - hence "snow." It freaks people out when they get random snowing, because it could mean they irrepairably damaged their very expensive video card. Glad to hear it worked out for him.
-SEAL
-SEAL
I thought it did, but when I put the quality sliders to maximum with 8xAA and 4xAF it came back :(. No snow on the mother nature test though, only Pixel Shader 2.0, I'm hoping that it'll magically fix itself, I'm not tech enough to still believe that this will happen :).
Both of my leadtek Ti4200s have snow on the pixel shader test. One has never been overclocked.
I'm just curious, but did your video card produce snow while booting? (I mean still in DOS before windows was fully loaded).
Nope, no snow when playing Morrowind with graphics maxed out or pre-windows etc, just Pixel Shader 2.0 when the settings are set highest.
Well I probably have the worst Radeon 9800 PRO on these forums, just fitted my VGA Silencer with Arctic Silver 5, thought I had cracked the core when I was tightening a screw, but fortunately I didn't.
My overclock is so so poor:
Core: 400.24MHz
Mem: 357.35MHz
How poor is that :mad:. At least my ALX-800 with AS5 seems to be running FSB208 stable so far.
3DMark01 = about 18,440
3DMark03 = about 6,080
Bad luck eh. I'm starting to think that my card is from Sapphire's reject line. I got the card cheap after a website cocked up the pricing and I had to wait about a month or two until the company could strike a deal with Sapphire where they're shared 50% of the losses together. Paid £135 for the what was then £280 card, so it's possible that it's just a reject card, or maybe I just got a bad one :(.
====Edit====
And the VGA Silencer took up 2 PCI slots on my A7N8X :(
====Edit====
