perl.. quick sanity check..
halz
I've got a one-liner in perl that works at the command line, but doesn't work within my script..
Code:
from the command line...
$perl -ne 'print if /Begin of text select/ .. /End of text select/' input.txt > output.txt
Code:
#within the script..
$content =~ /Begin of text select/ .. /End of text select/;
print $content;
...am I just not using the one-liner in perl correctly? Otherwise.. How else can I easily select a block of text from a variable containing multiple lines and print it..?
what is the script supposed to do? print out the lines between "Begin of text select" and "End of text select"?
i think the -n flag automatically wraps the code inside of a while(<>) loop, which reads each line (of the provided filename) into $_ until it hits EOF
if you werent using the -n flag, the command would be something like:
perl -e 'while(<>) { print $_ if (/Begin of blah/ .. /End of blah/); }'
so for the script to work properly, you'd also have to do so manually.
Ah.. thats the stuff.. I didn't question the -n option!
I've got it in a while loop and its working happily now.. thanks!
