I have Comcast as ISP. Using Motorola Surf Board SB6121 as modem. And have a WD N750 as my router.
Ever since I moved into the house I had this setup. My internet connectivity goes down about once every 5 to 6 hours. All of my devices would still be connected to the router but receives no internet connectivity. I have to restart the modem and the router
The time in between each connectivity issue sometimes is longer, sometimes is shorter. I called comcast to check the issue, the technician said nothing was wrong but he can try to boost the signal, which didn't resolve the issue. Then I turn to the router website and see if anyone else had this issue as well. I updated the firmware and turned off the dual band as well. This problem persists....so now i'm turning to you guys...anything ..any spark of ideas would be great! thanks
