Performance/price ratio
Ronnyy
Hi,
I have seen that most post of this forum is about expensive models, I have a question about inexpensive models.
I think there is a big chalenge in finding good quality for less money, and acctually finding the best Performance/price ratio.
I'm searching for a TFT just to replace my CRT, that is to small, and my eyes hurt a bit if I look more than 2-3 hours.
I usually spend 4-5 hours on my home monitor.
I'm searching for a good monitor, that shouldn't be exepnsive, I won't play games, and if I will play I don't really care if there will be a little gosthing. I will watch some TV(I'm planing to buy a tunner card) and watch some divx movies, and most of the time I will read articles and write programs.
I have picked some TFT from the nearby stores that I'm thinking of buying, but I don't know wich one to chose. I you know other models, just tell me. Bellow are the one that I found.
1)iiyamaE430S-B3
Formaat: 17.0inch
Brightness: 300.0cd/m2
Responsetime: 8.0ms
Contrast: 700.0:1
Angels h/v: 140 / 140
DVI: no
Price ~336USD
2)ACER AL1722HS 17 "
Responsetime 8 ms
Panel TFT active matrix LCD
Colour 16,7 M
Pixel pitch 0,264 mm
Input Analog/Digital
Angels H 150 /V 135
Brightness 300 cd/m²
Contrastverhouding 700:1
Resolutie 1280 x 1024 pixels
TCO99
Speakers and mic 2 x 1.5W
Kensington Lock supported
Price around 312USD
3)Belinea 10 19 02
Formaat 19 inch
Pixel pitch 0,294 mm
Brightness 250 cd/m²
Contrast 500:1
Response time 16 ms
Resolutie (max.) 1280 x 1024
Horizontaal 31-83 kHz
Verticaal 56-75 Hz
Angels H 170 º
V 170 º
USB-hub
TCO '99
Input D-sub
437 x 426 x 198 mm
model 2005
http://www.maxdata.de/application/p...arm01=118&parm02=100&parm03=111916&Register=2
Price ~ 375 USD
4)Acer AL1715MS 17" TFT monitor
ACER
Maximale resolutie 1280 x 1024
Pixel pitch 0.264 mm
Powermanagement VESA DPMS & TCO´99
Speakers 2 x 1 Watt
Response temp 12 ms
Plug & Play DDC 2 B
Refreshrate 75 Hz
Interface Analoog D-Sub
Type TFT LCD
Colors 16.7 Miljoen
Angels H: 150 gr V: 135 gr
Brightness 300 cd/m2
Contrast 500:1
Price ~ 311USD
5)Philips 17" TFT 170C Silver
Picture/ Display
• LCD Panel Type 1280 x 1024 pixels,
Anti-glare Polarizer,
RGB Vertical Stripe
• Panel Size 17" / 43.3 cm
• Effective Viewing Area 337.9 x 270.3 mm
• Pixel Pitch 0.264 x 0.264 mm
• Brightness 250
• Contrast Ratio 450:1
• Display Colors 16 M
• Viewing Angle (C/R > 5) - Horizontal : 160°
- Vertical : 140°
• Response Time 16 ms
• White Chromaticity, 6500º K x = 0.313 / y = 0.329
• White Chromaticity, 9300º K x = 0.283 / y = 0.297
• Maximum Resolution 1280 x 1024 @ 75Hz
• Recommended Resolution 1280 x 1024 @ 60Hz
• Horizontal Scanning Frequency 30 - 82 KHz
• Refresh Rate (V) 56 - 76 Hz
• sRGB Yes
Price ~287 USD
6) Belinea 10 17 35
Response time 13ms
1280x1024
Contrast 500:1
Brightness 300cd/m2
Best Regards,
Ronnyy
