Hi there; I've got a 512MB 7900GT that I'm running at 7900GTX speeds with a Zalman VF900-Cu. My highest stable overclock on the card is 675MHz on the GPU; whenever I go higher, my computer locks up and I have to restart. My temps never go above 61 degrees so I'm guessing that I need to voltmod my card to hit 700MHz.
For those of you that have 700MHz+ on your 7900-series cards, I was wondering if you noticed a big difference between that speed and, say, 650MHz. I'm trying to improve performance in Rainbow Six: Vegas and I was wondering if 700MHz on the GPU would yield acceptable performance with all the settings at maximum at 1280x960. I don't really want to voltmod my card but if it means that I can run Rainbow Six: Vegas one resolution higher, I'll do it.
Thanks for reading.
Thanks for reading.
