lithium726 said:the ee is extreemly overpriced and only marginally outperforms an 830/840 (especially the 840), especially for the price. it even loses to the 840 sometimes, HT doesnt seem to like dual core as much as it liked single cores.
zoz123 said:The only difference is hyperthreading. I found that Dell offers systems equipped with it and they are overclockable on air to 3.4 and 3.6 Mhz. I don't know to buy this one or a x2 4800, Dell will save me lots of money if I got the Intel.
Have you read this guys?:
http://www.overclockers.com.au/article.php?id=384519&P=7
Based on our results with PCMark 2004 we estimate that a Pentium D would have to run at around 3,450 MHz, that is 250 MHz more than the current 840 default frequency, to be on par with the X2 4800+. In a real life comparison the X2 4800+ would of course also be overclocked and the distance would probably remain the same.
Is that true that it can beat the 4800 stock with Air overcloking? if this will be the case, then I am buying from Dell..
erf said:i'm looking at a dell and am wondering what the performance difference between the pD830 and 840EE are? besides the 840 being 3.2 as compared to the 830's 3ghz is the 840 worth the extra $$$?
Donnie27 said:But no one asked about AMD!
Donnie27
Morley said:Donnie, you can run dual core, dual Opterons in Windows XP.
Microsoft has stated that their licensing is in regards to physical processors, not logical.
It still wouldnt beat it in gaming but might beat it in other things. It doesnt matter anyways, even with 2x 7800gtx's in sli the difference between a 3.0ghz p4 and a 3.2ghz a64 would be marginal at best as long as your are turning up the eye candy enough.zoz123 said:I am asking because I am consideing the P8400 EE and want to know if its overclocking to 3.6 would make it beat the X2 4800 in gaming or not.
seconded...Morley said:Please post that link.
Frankly, I have personal experience with not only the PD 840 EE, but numerous dual Xeon platforms with HT. I have seen first hand the difference between four logical and two logical processors. I'm not sure where you're getting your information.Donnie27 said:I don't have the links saved. Like I said though, I did post them here.
Donnie27
Morley said:Frankly, I have personal experience with not only the PD 840 EE, but numerous dual Xeon platforms with HT. I have seen first hand the difference between four logical and two logical processors. I'm not sure where you're getting your information.
3D Studio Max 7 and Photoshop both show a marked difference between 2 and 4 logical cores in Windows XP.Donnie27 said:Again, I know what I read and posted it here. In the past when I was wrong, I posted as much. This time I'm most certainly NOT! 840EE does slightly better than two Xeons with a similar config. I didn't talk about about Dual Dual Core Hammers, you did. I said it sould all the processors it likes, WindowsXP can only make use of Dual Threads on each app=P
Now you can Multitask to get better use out of it, but that not the say. I read the info at GamePC, 2CPU.com and others. I posted the links to Scali and others on a thread about 5 months ago.
Morley said:3D Studio Max 7 and Photoshop both show a marked difference between 2 and 4 logical cores in Windows XP.
http://www.gamepc.com/labs/view_content.asp?id=pee840&page=9
Continued on the next page.
GamePC said:In our tests, we only found a scant few applications which benefited from Hyper-Threading, some even performed slower. In the cases where Hyper-Threading does help, its typically between a 5-10% performance gain. Is this feature enough to justify the massive price hike over the standard Pentium-D? We certainly dont think so. We think Intel has made a very large mistake in relying on Hyper-Threading as their sold differentiator between their dual core product line. Its simply not an important enough feature to warrant such a large price gap.
its pretty much the same thing. you will never get 2x performance (at least not currently)Happy Hopping said:Is there any draw back of Intel dual core on over head? As a no. of yr. ago, in one of those Intel White Paper, they stated on sys. server w/ 2 CPU on SMP, the overhead is 0.5x, thus, performance gain on 2 x CPU is only 1.5x on performance. Likewise, performance gain on 4 x CPU is 3x, in other words with Quad CPU, the overhead is 1x.
What is the overhead on dual core? It's a master/slave relationship there has to be some overhead. The problem w/ overhead is if your CPU is not doing much, it still waste CPU resource to assign task to its slave CPU, wasting valuable CPU time.
Donnie27 said:WindowsXP can only make use of Dual Threads on each app=P
Now you can Multitask to get better use out of it, but that not the say. .
no...swirly said:I bought a dell with pentium d 3.0ghz, it sohuld be awsome..
Is a pentium D 3.0ghz better than a pentium 4 3.2ghz??
Blethrow said:Not true. I have an 840EE running four threads in a molecular biology program (Mascot, if you care) right now. This particular app is highly parallelizable and I see an ~26% performance increase on going from 2 threads to 4 by enabling HT. This processor easily goes above 4.0 on water, with no voltage adjustment, rock steady. Thus I get about 250% of the power I'd get from a single core w/ HT running at 3.4.
If you're still curious why I have such an obviously overpriced processor: this app I'm talking about costs about $2500/CPU in licensing. It sees a dual core as a single processor for licensing purposes (and sees my four logical processors as one processor). I''ll leave the math to you as an exercise.
Point is, this processor makes a lot of sense for some niche applications like mine.
Morley said:
xappie said:If you open up Task Manager, go to "processes", then in the view add in the "thread count" column you will see how many threads each process is using. As I am typing this, FireFox is using 11 threads. My virus software is using 42, and outlook is using 26!
I am using winXP pro and a P4 with HT.
Software Licensing Models
In order for multiprocessor systems to be effective the operating system must be able to detect multiple processors and provide a mechanism to schedule separate processes and/or threads on the physical and logical processors present. This is true for all the architectural systems discussed in this paper. Microsoft provides several versions of Windows* that have this capability, as do many Unix/Linux*-based operating systems.
Morley said:Ok, correct me if I'm wrong, but I believed you to say that Windows XP Pro can not utilize more than 2 processors at one time, regardless of how many it sees?
Am I correct, or do you in fact mean that it's an Intel issue only, and doesn't affect, say, dual core Opterons?
Ah, then I misunderstood you.Donnie27 said:Intel only and some negative affects of Hyper Threading, nothing more, nothing less.
Donnie27
ChronicTrees said:Keep in mind they were using an ES chip, they dropped the multiplier to get the fsb to 250 whatever and the chip was still only running 3.7ghz so it wasn't getting as hot as 250fsb on a locked one would be.
