Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What kind of performance increase do you guys get by overcloking your I7 920 system. Is there some sort of proportional increase from stcok speed to say 4.0 ghz?
With your graphics card you wont see any increase in fps unless the game is severely CPU limited.
Most games are GPU limited so they wont see a change.
Regarding CPU limited apps, you will see a % for % performance increase.
If you want specifics, be more specific
I work with 2GB size files in photoshop/illustrator/premiere etc. and the performance increase in my 9400@4.0GHz is insane in those programs. Your i7 would be a monster at 4GHz. Get to it! Good luck!
