Perfect motherboard and case combination
alanzhao
Ok, I am gonna build some more PCs for my friends in college since I built quite a few PC in the past. Because I bear a great responsiblity, I have to consider they will get the best PC components they can get for their budget and all the components can be intalled and ran without any hassel. My main consideration is the case and the motherboard, because they don't usually intergrate so well because you can't try them first and then buy. My frequent problems are motherboard standoff and case fan position mismatch, and power connector length shortage. Since my friends needs a varieties of cases, I definitely need a perfect combination.
So can any of you suggest a ATX or MicroATX motherboard and a case combination for either or both P4 and Celeron 2.4GHz. The buget for motherboard is under $70 and case is $50.
If you don't have any PC case preferences, good motherboard sugeestions are also welcome.
My other configurations are:
CPU -> Intel Celeron 2.4 GHz 400MHz FSB, 128K Cache
Memory -> Kingston 184 Pin 512MB DDR PC-3200
HDD -> Western Digital Special Edition 80GB 7200RPM IDE Hard Drive
CD-R -> Lite-On 52X32X52X16 Combo Drive
I prefer all the cases and motherboards can be purchased from NewEgg.com
Thanks!!!
