Pentosin Foaming?
J_Devil
Hey guys, really quick question about pentosin. I just finished my first Watercooling set up and I have it doing its test run and checking for leaks and the Pentosin (G11) I have in the loop seems to be foaming up pretty bad -- is it supposed to do that for a while? I heard that its normal for PC-Ice to do that, but anti-freeze?
Totaly normal, after all the "micro" bubbles bleed out, along with everything else, your fluid will be nice and clear. Pentosin is very good, so no worries.
PC ice is basically distilled water + antifreeze for the most part.
Just let it sit for awhile. Make sure you didn't add any more than 10% pentosin too.
Thanks for the responses, like previouse replies said, I let it run for a while and the micro bubbles bled out just fine - fluid looks good now :)
As they said, it takes time. However, for those doing this in the future. It's best to start the bleeding process first and then adding the additives like Pentosin later. This will result in less bubbles/foaming from my experiences cutting down on the bleeding time.
