nooooooo!!! for $350 you could do a whole lot better than a celeron m. is that $350 for the entire system or just a the cpu/mobo?J_I_M_B_O said:Yeah, I think, I'll try the celeron m. This is my first build and I've only got $350
I saw some good deals on the celeon m on ebay
o0akoni0o said:nooooooo!!! for $350 you could do a whole lot better than a celeron m. is that $350 for the entire system or just a the cpu/mobo?
sleepeeg3 said:The problem with going the Celeron M, is the uber cheapness of the chip is offset by the uber expensiveness of the board. A64s or Semprons are the better bang for buck and are going to handle everything but gaming a little better.
The P-Ms are great chips if you can score the parts inexpensively, but you have to agree that's alot to be spending for one piece of hardware that would normally cost you $75-85 new and $250 is alot to be spending to most people. You can get a 90nm, 2.0GHz Sempron 64 and TForce for under $200 and with Vista due out fairly soon, a P-M is sort of pointless.widefault said:Honestly, the boards are NOT that much more expensive than any other GOOD board. And there's always the option of an Asus P4 board with the CT479 adapter.
I've been lucky, two of my setups use refurb AOpen i855GME boards from Newegg that were around $130. This latest system was put together for around $250. That's board, CPU, memory, PSU, storage, everything. Granted, a lot of it is used stuff I picked up on the cheap.
sleepeeg3 said:Vista due out fairly soon, a P-M is sort of pointless.
