Pentium M Sc-478 ????????
Donnie27
I thought Intel wasn't going to make anything like this?
intel Pentium M 735 Dothan 400MHz FSB 2MB L2 Cache Socket 478 Processor - Retail
Model BXM80536GC1700F
CPU Socket Type
CPU Socket Type Socket 478
Processor Finder
Intel® Pentium® M processor
sSpec Number sl7ep
Processor Frequency
1.70 GHz CPUID String
06D6h
Package Type
478 pin PPGA Core Voltage
1.340-1.276 V
Bus Speed
400 MHz Thermal Guideline
21.0W
Core Stepping
B1 Thermal Spec
100°C
L2 Cache Size
2 MB Manufacturing Technology
90 nm
L2 Cache Speed
1.70 GHz Bus/Core Ratio
17
Spec Update
http://developer.intel.com/design/mobile/pentiumm/documentation.htm
Product Order Codes
Box Order Code
BXM80536GC1700F
OEM Order Code
RH80536GC0292M
This is an Intel® Pentium® M Processor 735.
I missed this, or are there reviews of this? Is this a Double Post?
Donnie27
Socketed Pentium M chips have 478 pins -- but fit in "Socket 479" sockets. (Intel states soldered in versions of the Pentium M have "479 pins" in the data sheet)
Newegg's description is just wrong, again.
But don't be discourged, several rumors point to the release of a Socket 775 Pentium M this year.
Please follow this link?
http://processorfinder.intel.com/scripts/details.asp?sspec=sl7ep
That's an Intel processor finder page. It clearly says-->Package Type
1.340-1.276 V
Bus Speed
21.0W
I even checked other models because I didn't believe it either.
745
Processor Finder
Donnie27
I went back and looked again, you're right, oh well.
Donnie27
I own the Pentium M 735. It has 478 pins, but it doesn't physically mate with the typical Socket 478 we all know and love. It fits fine in a Socket 479, however.
Thanks again for the info! Problem noted. More like wishful thinking on my part ;)
Donnie27
You do know about the adapter board, right? Asus makes an adapter board which lets you connect a Socket 479 Pentium M to a proper Socket 478.
Yup. I know about the Asus CT-479 or whatever it's called. Again, it was more of a hope than anything.
Donnie27
I got that same processor off newegg, and it was sealed when i got it, but it doesnt have a HSF even though they advertize that it does.
That sucks!
Donnie27
pxc said:
LOL... ok
We'll see.
I heard the rumors too and that's what help through me off. If the VARs pushed Intel, yes, Intel will sell them=P
Donnie27
