Pentium M Motherboard
pigpen
Might sound like a stupid question, but i'm new to M CPU's. Will a socket 478 Pentium M be compatable with any 478 MB?
Thankyou,
Nope it will not.
Pentium M is a socket 479.
There are only a few companies making mobo's for pentium M's.
The two biggest are DFI and AOpen.
There are several smaller companies making some mini-itx versions.
Tracking down a mobo is the hardest part they are not exactly stocked well in most places. I will see if I can find a link to place that sells the mini-itx version it look pretty nice. The other big problem they are quite expensive starting about $250 each.
I believe Pentium Ms are socket 478 as well, but their pin arrangement is not the same as socket 478 Pentium 4s, so they won't fit in the socket.
I've been looking into this myself over the past few days here's the lowdown.
1. Pentium M's have 478 but in a diffferent arrangment than normal P4's
2. They overclock real nice.
3. There are only two available at the moment from DFI and AOPEN
4. They use the 855 mobile chipset which doesn't support pci express so if you were hoping to use sli your out of luck
5. The mobiles are very exspensive unless you buy them off ebay.
6. The motherboards are 275 + which means you could get a 3.2 and overclock that rather than get a mobile. and save money. The mobiles go for like $200+ to start on Newegg but the ones on ebay are like only $100
it's cheaper to wait until the price of the boards come down or buy another system that will oc well
Thankyou very much for the help all. Umbra, you're right man, who whould'da thought? About 25% cheaper off ebay than online. Thanks for the heads up :)
While i would agree that those MB prices are pretty high, a CPU/MB combo for around $500-$600 with the OC'ing potential this guy has is gonna be worth it for me and my upcoming build. 2 MB cache and running on less than 1.0V; definitely worth looking into.
What do you guys think (or know) about the way i'm looking at this?
Even with all that OCing potential, I probably wouldn't spend near $300 on a motherboard unless I were building a workstation with dual procs.
I'd personally wait until next year when Intel release the newer Pentium Ms and we see more desktop Pentium M hardware out. (But then again, I already have a Pentium M in my laptop).
HEY D00D!! they have SOCKET 479 MOBOs at newegg, Im sure about this cause I just checked it yesterday... and I was saying to my self WHAT THE HELL IS SOCKET 939!!.
Socket 939 is a the dual channel Athlon64's and most of AthlonFX.
Oh shit they now have Pentium M boards at newegg that must have been very recent because I am sure I check less then a week ago for one.
they added them about a week ago
