"715A" isn't an Intel name for the processor. The 715 is a "Pentium-M 1.50A GHz" (2MB L2). It looks like some manufacturers (or maybe just Toshiba) are moving the A from the speed portion of the name to the 715 part number to differentiate it from the older Pentium-M 1.5GHz CPUs (1MB L2).
Yeah, look up "715A" on intel's web site and there's nothing. No addendum, nothing. But if you look up 715, you'll see it's called a "1.50A GHz" by intel.
I noticed Toshiba, and sometimes Compaq, are using the name "715A." It's pretty consistent: 715A = 1.5GHz, 2MB L2, 400MHz FSB. But it seems to be exactly the same as the regular 715 that intel lists.
This Intel(R) Pentium(R) M processor features 1.5 GHz processor speed, 2MB L2 cache, 400 MHz front side bus. It delivers good value if you're looking for speed with mobility.
Intel(R) Pentium(R) M Processor 725 (1.6 GHz)
This Intel(R) Pentium(R) M processor features 1.6 GHz processor speed, a large 2MB internal L2 memory cache, and 400 MHz front side bus speed. These mobile-series processors include power-conserving features to extend battery life.
Does this mean the A doesn't have like speed step or something or are they just trying to get you to buy the more expensive processor.
