FreiDOg said:Core Duo is Yonah, the dual core Pentium M chips. You can't upgrade to them from a Penitum D because they're a different socket.
Conroe's title at release will be 'Core Duo 2'
It's currently supported by a few of the 975X boards, the Intel 975XBX Rev304, the Asus P5WD2-E Premium, I think a few others but I can't quote boards right now.
viper650 said:this chip is not supported by any asus boards out. why do i keep seeing this so often here?
FreiDOg said:Conroe is supported by the 1.03G rev of the P5WD series, you just need a BIOS update. Though you're part right, I think even the P5WD2-E started as a 1.02 rev which won't support Conroe - but buying one now you should get one that supports Conroe with a BIOS update.
The 1.03G rev updates the motherboards voltage regulator to be compatible with the VRM11 standard required for Conroe.
viper650 said:do you have a link to this?
