chrisf6969 said:1st. You know there's a thing called "Search", look at the little maroon bar across the top. THat could have probably helped you greatly.
2nd. AMD 4000+ is single core and different category. I'd be comparing a 3800+ to the 920D as they're both dual-core.
3rd. I have a 920D it hits 3.9Ghz at default voltage and is faster than an FX-60, 955XE or FX-57. It will hit 4Ghz with a little extra voltage (@ 1.3625v) But I like to keep it cool & at default voltage so I "only" run it a 3.9Ghz.
You can see my benchmarks here: http://www.crowdcontrolusa.com/overclock/shizzy2.html
4th. You might want to also consider a Pentium D 805 as they've been hitting around 3.8Ghz for half the price. (So you can afford either more ram or better videocard)
Psycho said:Thanks chris. I think you pretty much sold me on it.
What kind of cooling? Damn, you're only a few C above me at full load last time I checked and well, yeah.chrisf6969 said:
SSE4 said:What kind of cooling? Damn, you're only a few C above me at full load last time I checked and well, yeah.
(As a note, I agree. The D920 is worth your money and an excellent processor - especially with it's overclocking potential on air)
chrisf6969 said:Thermalright XP-90C with generic 92mm blue LED fan. (fairly quiet, nothing fancy like a Vantec Tornado)
65C isn't too bad for 2 full cores at 4Ghz.![]()
chrisf6969 said:b/c I was testing CPU stability not memory stability.
My memory wasn't pushed so that test works fine and it seemed to work fine for testing CPU stability.
StealthyFish said:yes, the 9XX series should all overclock about the same (4.25 Ghz on stock cooling guaranteed)
