Pentium D 830, Upgrading to 955 EE
onin
Hello guys I am thinking of upgrading my Pentium D 830 to a 955 EE is it worth it ?
Well, how much are you paying for it? IF its used & really cheap, MAYBE. But its NOT worth it, if its anywhere near $1000!!! My 920 did 965EE+++ speeds, and I paid $280 new for it.
The 900 series run cooler and overclock to 4Ghz much easier than the 800 series. So they are better, for those 2 reasons, but they perform nearly identically. 830 = 930
If you're an overclocker, I'll sell you my 920 for cheap, it hits 3.9Ghz at just a little over default voltage. Or you can run it at 3.73Ghz (same FSB & CPU speed of the 965 EE) at default voltage.
I didn't keep it at 4Ghz, b/c it ran too hot, but it is capable of doing it, and maybe more with good cooling.
see it & benchmarks in my old system here:
http://www.crowdcontrolusa.com/overclock/shizzy2.html
Im not an overclocker, but I saw one on ebay thats brandnew around 400-500 I think its a good deal. but let me research more. thanks for the reply.
eeeeh, not really a good deal considering the 950 sells for like $180 (used) to $250 (new)
or a 960 which would be faster for like $350.
http://www.technologydepot.net/product.cgi?product=273606&group=207294
or my 920 that's guaranteed to hit 965EE speeds at default voltage ( = means it won't run any hotter than a stock 965EE) for $150.
Performance wise definetly.
Price wise , only if you can find it cheap.Offer no more than $300 for it.
loxety said:
No way its worth it. a C2D would be worth it.
His mobo probably doesn't support Core 2 ? At least thats what I'm assuming.
B/c if it does then he should get ANY Core 2 chip over ANY Pentium D.
b/c e6300 > 965 EE
But for $400-500 that the 955EE was selling for.
He could get a DS3 or P5B-E and an e6400 or e6600 and still have money left over.
and an e6600 > FX-62 > 965EE, etc
Yup thats correct, my mobo does not support core2duos, kinda in tight budget now. anyway. Im gonna try to find some deals.
Does it support overclocking?
The cheapest I've seen the 955 go for is $350. I priced it over the course of 3 weeks recently and it's a little too pricey for what you really get. Sure, you get the 1066fsb and technically a netburst based quad...but for $350?!?! I'll probably get one when I can pick it up for $200 which I'm pretty sure isn't gonna happen.
I recently upgraded my other rig to a 950 as well and I coudn't be happier. Both rigs are running a stable 4.1ghz on air...idle @ 36C and load @ 41C. I bought the 2nd 950 a few weeks ago on ebay for $170 shipped to my work.
The best bang for the buck among the Pentium Ds:
945 - 3.4ghz of dual core for $165 all over ebay and easily hits 4ghz
950 - every so often pops up on ebay for $165-$170
805 - you can run this to 4ghz but you need good cooling which is pricey
Shoot me a pm if you got any questions....
Later!!
yup It supports Overclocking but I dont overclock. :D maybe Im gonna call it off, Im will try to save money for xmas and get the core2duo with the motherboard.
Pentium D's were made for overclocking. I've got my 950 at around 4.2Ghz stable on my XBX. Amazing processor. Every action i make is snappy and responds almost immediately. If you need a CPU now, I think anything in the PD range is good. Don't listen to the guy who's trying to sell you that stuff, it's not hard to get ANY pentium D to 965EE speeds... my 950 is higher than an EE. Hell, my 805 is running faster than the 965EE as well, not that glorious.
If you don't need the CPU now, then just hang on for a bit and get a Core 2 Duo. You'll be better off in the long run.
You're right nearly any Pentium D 9xx (Presler) will hit 3.7Ghz++ with an overclocking motherboard. (voltage adjustments & fine FSB tuning)
BUT PAY ATTENTION: he's got a dell that doesn't support overclocking (NO VOLTAGE ADJUSTMENTS or fine tuning the FSB). The only thing HE MIGHT BE ABLE TO DO, is a wire mod to the motherboard to trick it in to booting at 1066FSB. Not many chips will hit 1066FSB at stock voltage!! My 920 will hit 3.73Ghz (1066FSB) at default voltage.
To overclock any of the 9x0 chips he would need:.
a 920 that could hit 3.73Ghz on default voltage or
a 930 that could hit 4.00Ghz on default voltage or
a 940 that could hit 4.26Ghz on default voltage or
a 950 that could hit 4.53Ghz on default voltage or
a 960 that could hit 4.80Ghz on default voltage
Obviously the only choice for a big improvement in performance
would be either a 920 overclocked
or a more expensive 950, 955XE, 960, 965XE, etc..
