Pentium D 830 3GHz
kyosho1
anyone have this cpu? my temperature slowly rises to 50c IDLE with this thing, is that normal? im using the cooler master hyper 212.
Pentium D's are hot CPU's.. but check to make sure you've got good airflow and the cooler isn't clogged up with dust.
Yes that is normal. At least this is what I see on the 2 similar systems I have in the department.
