Pentium D 805 Temps
Karant
I have a Smithfield Pentium D 805 clocked at 3.5GHz with the stock cooler, and am just wondering what the temps on idle and load should be around, and whats too hot, and whats not. thanks!
mine that i used to have got to 3.6 and had temps of 25-35c with a zalman 9500...
so id say count on around 35-40 give or take 5..
thing that kept me from ocing more was the PWM temps
:::edit that doesnt matter but i feel like saying :p::: just for shits and giggles i managed to do this:
running at as a dry pc (no case) By my window :)
What abit mobo are you using for the 805d? Looking for one that can oc like a fiend, but I'm not sure if the new P965 and 650is will oc as well with the pentiums as they do with the c2ds.
Abit LG-81.
sorry Karant for partially jacking this thread, but yea, you should get about 35-40c.
I get 40 (idle) to 70 (load) degrees, is this bad?
wow that is pretty high, in my opinion...
do u possibly have too much thermal grease on it? like is it thicker than like 1/3 of a millimeter? thats about how much should be on there...
or are you using the stock pad?
