Pentium D 805 Overclock with Tuniq Tower
Kanaric
Managed to get to 3.9 ghz. Tried for 4 but windows wouldn't boot. I'll probably try 4 again later and see if I play with some other settings if it will work.
44 C idle, speedfan says its 56 on full load during a benchmarking program on infinite loop.
This is my first at a cpu overclock that I intend to use full time. When I wanted to build this system it was my intent to only overclock it to 3.6 ghz to begin with and then try a bit higher later on when I get some more knowledge on this.
This was done with:
P5n-e SLI
OCZ DDR2 800 Revision 2 2x1gb - running at OCZ's intended settings of 4-4-4-15
Stock the voltage hung around no more than 1.280
There are some things i've been wondering before. I've never overclocked a cpu by this much, ever, and i've never really played with voltages before. I usually like to run my computers 24-7 is their any danger with the increased voltage and fsb by this much to the cpu? I dont know much but i assume since the temperature idles 38 that it should be fine, unless higher voltages put intense stress on the chip or mb.... that i dont know.
I dont have an accurate temperature gauge except in bios. In Windows i'm forced to use speedfan since nothing else works on this board, lol. If you know of a good one that works on this board i'd be pleased to know.
I'm going to try to push it higher, to 3.8 or even 3.9 or 4.0 if I can after i'm sure this would be ok to run like I intend.
edit: I notice in cpu-z the voltage jumps around a lot, i hope that isn't a problem.
the highest i've ever seen one of those was 3.9 on air. nice oc so far, though.
lol, I had mine at 3.8 ghz on the STOCK COOLER. I backed it down to 3.6 because i was up to about 65 degrees in 3dmark 06 and I have a blue orb ll on the way to try and hit 4 ghz. What would you guys say would be a safe temperature for it to be at for 4 hour gaming sessions?
i'd push it higher but i dont know what the effects are on a processor when you have voltage up to like 1.4-1.5 when you run a computer 24-7.
I'm sure since its idleing less then 40 C at this that it could get to 3.9 at least.
If I knew that it wouldn't be harmful to raise voltage high and run a computer for that long then I would be going all the way.
Tried for 4 GHZ but failed to reach it, windows would crash on boot.
Anyways I managed to get it to run stable on 3.9ghz
Runs 44 C idle, successfully ran 3DMark06 a few time in a row without crashing.
