Pentium D 805 Bottlenecking?
Karant
Alright, I've been getting really low FPS in games such as Battlefield 2: Desert Combat and Day of Defeat: Source, regardless of my visual grahpics settings. Could this be because my Pentium D 805 @ 3.5GHz is bottlenecking? Whats the issue? Thanks alot.
When I had pentium D 805 @ 3.6 ghz with a 850xt. Battlefield 2 was definitely bottlenecking.
I used to get 25-45fps with the pentium D and when I switched up to core 2 duo @ 3ghz I was pumping 45-90fps....
Was that with the c2d stock or overclocked that you noticed the gain?
Karant, first try upgrading memory to 2gb, Battlefield is really memory-hungry ;)
I agree. I tried 1gb when i first got my memory and played Bf2. It sucked. Popped the other gb in there and it was fine.
I had 1.5gigs of ram and overclocked the core 2 duo a bit. I was gaining averagely 40fps.
Exact same setup except the CPU.
Another vote for more memory. 1GB is simply not enough for anything but the lowest of settings.
Is my CPU really outdated, will it bottleneck in most new games? Is my motherboard (ASUS P5LD2-Deluxe) compatiable with any Core 2 Duo chips? Thanks.
With the x850 XT?
Sorry about the triple post, but would it be worth it to upgrade to a Pentium D 945? Thanks.
Sorry about repeating myself, but is my CPU really outdated? Will it bottleneck in most recent games? Which newer games will I notice this bottlenecking in? Thanks.
First try upgrading memory to 2gb, since you got ddr2, you'll be able to reuse it with c2d anyways. Also try overclocking and see how added memory and oc helps out.. There's no reason to upgrade cpu and mobo for $300 if you can get something out of your current setup with moderate investment in memory which will need anyways for the upgrade ;)
I'd say more ram and more video card.
I got a similar setup, expect, I have more ram, and a 8800 gts 640mb.
I run hl2dm with all settings maxed and wide screen resolutions with no probs.
I don't think it is much of a bottleneck. More ram, then video card. Sure a c2d will get you a few more fps but nothing like a new video card.
The 1st time you asked the question, the answer was:
Your cpu is good enough, but you need more memory
The 2nd time you asked the question, the answer was:
The 3rd time you asked the question, the answer was:
The 4th time you asked the question, the answer was:
Your cpu is no core 2 duo, but it's not your main bottleneck, and you need more memory
Where exactly are you getting confused here?
I am confused here, you mean to say he needs more ram?:cool:
Crap with my 2GB I feel I need more RAM now ...
Sigh another pay-check .. bye byeee :p
