Hi Guys-
Many of you know my straight up AMD bias, but I'm not one to overlook facts. So that means come Feb/Mar I'll be picking up a Q9450 and moving the build in my sig (sans Ultra) into an HTPC case for home theater duties.
However, I have been out of the Intel loop for a long time, so I'm in need of suggestions.
My budget is fairly flexible (as I think most enthusiast budgets are), but coming from AMD's full featured $70 motherboards I find $300+ incredibly hard to swallow. In the $100-$200 range would be best.
I'm looking for:
How does that sound as a set of requirements? It's funny how if someone asked me this for the K8/K10 side of things I'd be able to reply in a second, but there you go.
A quick aside: am I correct in understanding that the FSB of Penryn is 333mhz, which would call for DDR2-667 RAM to run 1:1?
Any and all help is much appreciated.
I'm looking for:
- Great overclocking capabilities -- Meaning it's overclocking friendly and stable when cranked to eleven. CPU will be watercooled by parts in sig, and paired with some 1066 Tracers to assist.
- Reasonable feature set -- I'm a simple guy, so I don't really care about extras like wi-fi, firewire, etc. SLI/CF support isn't necessary, though I may go with it if the price difference isn't too steep.
- Speed -- I'd like a board somewhere in the top end of the bench charts for subsystems.
- Native Penryn Support -- This may sound obvious, but considering a lot of people don't read the whole post I thought I'd add it here too
