Pendrive problem under XP
ksawery
Hello,
I hope you can help me here ppl, because you have proved that you are wise.
So, when I put my Pendrive into the USB port of my laptop nothing happens. I mean, you can notice the icon in the systray with which you can safely remove the device.
By when I open My Computer I can't see the Pendrive icon that used to pop up after I inserted the Pendrive.
BTW, when I click on the icon in the task bar (like I would do back in the days to remove the device) the is a not very well looking icon.
I am running Win XP Pro SP3CR.
Help pls!
