Peltier?? yes/no?
Spyder
i have a swiftech set up right now swiftech cpu and gpu blocks ehiem 1250 pump black ice extreme 2 rad with a 120 delta on it.. anyways i was wondering if i got a peltier its a 226W pelt.. and used a 550w PS to run everything.. cpet the pump that goes off my wall... what kinda temps could i expect it says on the site its maximum operating temp is 125C that mean i got to keep it under 125c and i will be cool... do you think my current setup will beable to handle it and...? what kinda temps do you think i can expect.. its only 50 canadian so i was going to give it a try
ill try, english is my like ummm 4th language so its kinda, odd to rember, all the rules that apply.. but back to the pelt? any idea's any one have one what kinda of temps you get?
Go over to Overclocker.com -> Tips & Tec -> Peltiers.
They have all the formula and data needed to calculate what temps you could run at.
Luck........:D
can you post a link to that site i went to www.overclocker.com seems to be some sort of porn site.. i did not really look cause am at work right now post a link please
