viperdv2k4
- Mar 7, 2005
viperdv2k4 said:Hey, have a swiftech storm waterblock and i was thinking about peltier cooling my cpu. Can i put the waterblock on the peltier? Im kinda noobish with peltier cooling. Also , i have a seperate Thermaltake Purepower 410W, can i use it to power the peltier? Do you have any suggestions for peltiers? Also, what happens with condentation and how do u protect against it?
Thanks
jinu117 said:It definitely is fun toy and you can find about insulation in swiftech store for manual on their peltier kits, Danger Den, or general idea from any of vapor phase change systems. As for efficiency, this is actually worst way to cooling though![]()
fore1337 said:Jinu I want to bastardize my V2000 to look like yours. Where did you get your phaze change kit? Is that thing a vapochill or a home brew job?
Viper, if you're getting into TEC you should look into the blocks which don't use 'jet-impengent" nozzles. You need something like a maze-4 that slowly distributes the water over the entire block in order to properly utilize the TEC.
edit: or get one of these: Wintsch Labs Arctic Web Liquid Cooled 437Watt Thermoelectric Assembly
I was posting about 1 why go TEC? post a week several months ago. (exaggerating)
well, it's already been said, but it remains important enough that i will say it again: the storm is not a block to use with a pelt. i don't believe that the base is large enough to accomodate a usefull pelt for a CPU chilling. there are no retention holes for installing the pelt and cold plate. the storm only cools the central area of the base plate to any usefull degree.viperdv2k4 said:Hey, have a swiftech storm waterblock and i was thinking about peltier cooling my cpu. Can i put the waterblock on the peltier? Im kinda noobish with peltier cooling. Also , i have a seperate Thermaltake Purepower 410W, can i use it to power the peltier? Do you have any suggestions for peltiers? Also, what happens with condentation and how do u protect against it?
Thanks
