pelt to cool second water block
titan151
Hi all,
OK some more pelt related action.
Has anyone tried using a pelt to cool a waterblock that is installed in series with another waterblock that cools the CPU. I read an article somewhere on this but can't find it. This sounds like it might be more promising then trying to cool the radiator. Any info apreciated.
Originally posted by titan151
Hi all,
Yes, that's called a waterchiller. The problem is that you need another watercooling loop to cool the peltier and an even better/bigger radiator in that loop.
no you dont need another water cooling loop just dont use a 226W pelt. I have been testing a 55W pelt for a little bit, and have a 95 sitting right here thats waiting for a power supply. I stuck the 55W pelt on another waterblock with a stock barton heatsink and fan on it and it droped my temps 6 degree at idle, and 5 load. I'm in the process of building a custom watercooling box, where everything will be in a custom alluminum box im making, with high flow quick disconnects on the tubes leading ot my computer, so i can move everything around easily.
I just did this so I'm still testing everything, just wanted to find something to stick my pelt on and its working great, I'll be posting a work log next week some time to show you guys everything its going to be crazy, and if i have room in my little external watercooling box, ill stick in the 95W pelt chilling the water.
Yes but in order to run it without a radiator you need a powerful enough peltier or several lower power peltiers to pump the heat generated by the CPU and whatever else you're cooling. So yes, you could use several smaller air-cooled peltiers, but then you'd also need more chiller blocks, fans, heatsinks, etc...
