Peer 2 Peer issues with Network
IInfernogd
Problem: Internet works fine on my new computer, the problem comes from peer 2 peer connections. In short I am unable to fully connect to people in peer 2 peer situations (torrents like WoW's patcher / regular torrent programs). On my old computer I could get full clear connections. (if any of you are familiar with torrent programs yellow means not fully connected, and green means full speed and connected completely in p2p)
How I fixed it last time: I had to teak some network settings on my older motherboard and network settings to get the Gigabit network adapter going full stream. However I can't for the life of me remember almost 2-3 years back what exactly those settings were.
Any suggestions? -- Spec's and settings included below --
**Running through router - all the ports are correctly open and port forwarding is already set up. This is the Host or Main computer in the network it has no firewalls installed currently**
Hardware:
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI
LAN Spec's:
Onboard LAN
LAN Chipset Realtek RTL8211BL
Max LAN Speed 10/100/1000Mbps
Connector - RJ45 Gigabit Lan port
Network list:
NVIDIA nForce Networking Controller
1394 Net Adapter Connection 2
Drivers:
Latest drivers from MSI website.
NVIDIA nForce Networking Controller driver version - 67.1.5.0
1394 Net Adapter driver version - 5.1.2535.0
Operating System:
Windows XP pro 32bit
Connection:
Cable 10mb down Static connection
Running through a router with all the proper ports open and port forwarding setup (previously setup for my other computer).
Current Network settings & Installations:
Settings for nForce Controller:
Flow Control - Off (Default: On)
Low power state link speed - Off (Default: On)
Network Address - Not present (Default: Not present)
Optimize for - Cpu (Default: Cpu)
Priority & Vlan - Disabled both (Default: Disabled both)
Speed/Duplex settings - Force 100 Full Duplex (Default: Full Autonegotiation)
Wake on Magic Packet - Enabled (Default: Enabled)
Wake on Pattern - Enabled (Default: Enabled)
Wake on Lan from Power off - Enabled (Default: Enabled)
1394 Adapter does not have any adjustable settings listed.
Power management: Unchecked allow to turn off device.
Installed on nForce Controller:
  • Client for Microsoft Networks
  • File and Printer Sharing for Microsoft Networks
  • QoS Packet Scheduler
  • Microsoft TCP/IP Version 6
  • Internet Protocol (TCP/IP)
Installed on 1394:
I would guess that your ISP is blocking the port you are using or your router is being overloaded with connections.
When you say you have forwarded ports... did you forward both TCP and UDP? I'm at work and so I can't check my router... but I think I got the TCP/UDP (Or is it UPNP???) terminology correct.
P2P like Azureus used both, and you have to forward both.
One port is enough, and don't use the default port provided by your P2P software. Pick some random port... like 5555 or something.
