Pcpc 510 Sli
Jasonx82
Anyone know if i can order a 510 sli from PCPC "directly" and customize it to ask them to remove the floppy power cable, I will never use it.. :confused:
IIRC, you can basically customize the types of connectors for a flat fee, provided you aren't doing like ATX to EPS12V. You'll have to call them for a current quote on that, but I can't expect it would be overly much.
And cutting the cables would void your warranty.
cutting? :p
