PCP&P 510 deluxe enough?
menlatin
SO i just got my psu back, 510 deluxe, and i'm thinking about getting another 7800 gt. I burnt this up, if some of you remember by putting a 320 watt paltier into my mix. Here's the system
Evga N41 Nf4 SLI Mobo
x2 3800 @ 2720 1.52v
Evga 7800 gt (500/1300) hoping to get the same with the second one.
4x 7200rpm hd's
1x dvd rw
1x dvd-rom
So, my question is, will this psu keep up with a nother 7800gt in the mix? I;m pretty much trying to get this 2nd card thourgh trades, and i dont really have the money to thrown down on an 850 or 1k psu. I could probably get by with adding my crappy psu to run just cards though. but thats not pretty.
It should do just fine.
Also, next time you want to thermoelectrically cool your CPU, buy an auxiliary power supply.
yeah i figured that out the burnt, smokey way.
Oh wait, i for got to mention, i plan on volt modding bot 7800's to 1.5/2.2, shooting for 540/1350 on each.
still plenty
this side of adding another 6 HDDs in a RAID array (for a total of 10)
you should be golden
(even if you did add that many drives, if you had them stagger the spinup youd still be OK)
