So now that PC Power & Cooling said it doesn't void my warranty if i replace the fan myself i am going to go ahead and replace the fan in my power supply.
I need to know what would be a good replacement for a
Delta EFB0812EH (specs to follow)
*Fan Speed 5000RPM
*Volumetric Airflow 52.02 CFM
*Acoustic Noise 42.5 dBA
I would like a much quieter fan with similar, or hopefully better specs. It needs to be pretty close to silent, but a small noise is fine. I have on hand an Antec 80mm Blue LED fan. The specs of this fan are
* Fan Speed 2,600 rpm (avg.)
* Volumetric Airflow 34 CFM
* Acoustic Noise 30 dBA (at average rpm)
I dont think this fan will be able to handle the kind of heat that the PC Power & Cooling 510watt Deluxe SLI.
I dont want to spend arm and leg for a "high end" fan. I am willing to spend around $40 if it is the best i can get for silence and the about of Volumetic Airflow i need (52.02 CFM) or about that much, and it needs to be 80mm because it would need to fit inside the power supply.
Thank you in Advance for your Advice.
*Fan Speed 5000RPM
