Pcie5 doesn't work when pcie2 is being used
PontiacGTX
I have purchased an used z97 xpower used for ln2 and the owner tested all the pcie but I have an issue that the Mobo doesn't detect a video card in pcie5 I have tried moving the ceasefire switch but it doesnt change anything,I have removed the VRM/mostfet heatsink to clean the liquid electrical tape but the heatsink also cover the PLX,that could be the reason why it happened?
Then the pcie slot could be damaged?
do you have a gfx card in PCIe slot 2 when you are trying slot 5, if not that is your problem as the primary gpu must be in PCIe slot 2. If you don't have you tried resetting the BIOS? Also make sure the card is in the slot properly
Looks like the config is as follows? For 2 cards it is PCI_E 1 and 5.
