Are there any video cards for PCIe x4? I've seen a few for x1 but it would be nice if I could take full advantage of the x4 bandwidth.
If not are there any decent x1 cards that can play videos smoothly at 1280x1024 or higher resolution?
Okay - clarification time.
What mobo are you dealing with now that has a physical 4X slot?
I've seen physical X16 slots that only have X8 and X4 lanes enabled. I've seen X8 slots. I've seen X1 slots. What mobo are you talking about specifically?
http://www.tomshardware.com/2004/11/22/sli_is_coming/page8.html
http://www.tomshardware.com/2004/11/22/sli_is_coming/page10.html
Pay extra attention to the gaming benches on the bottom link. You'll be fine.
And by the way, you could always do what MSI did with its K8N Neo4-F: the board has a physical/electrical x4 slot, with the back wall broken off the connector. As a result, you can plug in an x8 or x16 just fine, it'll just hang on empty space over the unconnected parts. Break off the back wall and you can use ANY card. Yes, they're all upwards- and downwards-compatible.
