cocheese256
- Apr 23, 2005
I am about to put together an I5 build. I see some of the revised p67 motherboards are trickling in. I plan on running either crossfire or sli. I see in the specs of a lot of mobos where it says 1 PCIe x16 (or 2 PCIe slots at x8). Other boards are showing 1 PCIe x16 and 1 PCIe x4. I see most of the two PCIE x8 boards are snatched up quickly.
Which would you recommend and/or is it that critical of a difference?
Thank you.
Thank you.
