- Oct 7, 2000
two titan v's will do it.
When a single GPU shows a fps drop between 16x to 8x, then that will show when we have truly reached the limits of that generation of PCI-E, at least with gaming benchmarks, but not necessarily scientific/compute applications, though.
exactly what shows is that the game mGPU with multiadapter isnt the bestIf you look at his chart around 6:30 on the video, it shows the fps on both 8x and 16x on a single GPU is the exact same (37.6 fps on both), which shows that the limits have not truly been reached in the classical sense.
Any generation of PCI-E will show limitations when using SLI without a crossbar (I know the Titan V GPUs don't support it), but it was like this back when 6800GT GPUs were all the rage with PCI-E 1.0 as well when a crossbar wasn't used, and the fps would dip quite a bit.
I don't want to say this is "cheating" to get to the PCI-E 3.0 limitation, but it is a bit of an artificial way of doing so on any GPUs (other than the Titan V GPUs since they legitimately don't have the capability).
Nice video, though, it was very informative.
Do you mean the SLI crossbar?exactly what shows is that the game mGPU with multiadapter isnt the best
Because it is up to the developer to optimize it and this isnt technically the same as running AFR with the profile of AMD.Nvidia over pcie.Do you mean the SLI crossbar?
Why do you say "it isn't the best"?
I'm not defending the crossbar or anything, but all it shows, and what has been known since NVIDIA's SLI inception, is that when using SLI without the crossbar causes that data traffic to be sent over the PCI-E lanes, thus causing more traffic/overhead on them than was originally planned.
Only very low-end GPUs and these Titan V GPUs don't utilize the SLI crossbar, and in the case of very low-end GPUs, there isn't enough traffic to bottleneck anything due to the GPUs being the limiting factor and not the PCI-E lanes.
With high-end GPUs, like the Titan V, the bottleneck becomes apparent due to the increase in data traffic.
Not sure what you mean by "it isn't the best", when this is just simply showcasing how the data is simply re-routed when the SLI crossbar is not present, and its effects when done so.
That's a very good point, and I see what you are saying now.Because it is up to the developer to optimize it and this isnt technically the same as running AFR with the profile of AMD.Nvidia over pcie.
AMD has been running CF with PCIe bandwidth and no one has shown proof that it gets bottlenecked in many games, otherwise people would be complaining, like those with R9 Fury CF or 290x
also iirc that once SLI bridge bandwidth is almost used nvidia starts using PCIE BW for the communication(i think someone wrote that on THw?
