PCI slot
WalkinG
Hi,
I'm just wondering, what you put in the PCI slot of SFF? Soundcard, NIC, I/O ?
most of the P4 guys put a different sound card, b/c the stock one sucks
i have a shuttle sn45g w/ soundstorm audio, therefore i use my pci slot for my gigabit nic card
some of them have TV tuners,
the people with temperature paranoia uses the pci slot fan
What you use it for? I don't think there is much difference to 100Mb card, couse' it still uses 32bit PCI slot.
the onboard nic lets upload at a maximum 10mb/s
the gigabit nic (when connected p2p) gets 30mb/s
the gigabit nic and my 16port switch/and 1 gigabit port, lets me swap files with great speed and ease... its a huge difference when many people are pulling large files from you at once
I put in an Antec PCI slot fan. Not sure how much it's really doing, cuz the CPU temp is still up at 55C.
You don't get the full gigabit speed with a 32bit slot, but you will get an improvement. I went from around 90mbit with my 100mbit network to 225mbit using gigabit. Definitely helps when transferring large files around the network.
I have a Leadtek WinTV2000 Expert... watch tv on it. One less thing to move around every 4 months...
but...PCI has 32 bit / 8 bits/bytes * 33,000,000 hz = 133 megs a sec transfer. Gigabit translates to 1000 mbit / 8 = 125 megs a sec, assuming 5 megs overhead, it should be fine...
Mine is being used right now as an HTPC, so I use the PCI slot for a 802.11G wireless NIC. The audio is perfect into the optical port in my reciever ;)
yes but that data has to come from somewhere ;)
Audigy2.
in the past, I've had a Leadtek TV-2000XP(w/ internal audio mod), a Hauppauge PVR-350.
But, with the P4 systems...Audigy2.
