Hello friends,
I've been given the assignment to set up a new PCI SATA controller on a co-workers PC. Anyways, it's needless to say that I'm running into problems. Here are the directions that are posted on the SATA controllers' manufacturers website (located here: http://www.koutech.com/faq.asp?category=IDE)
I've been following this procedure 100%. However, when Windows installation looks for the controller drivers on the A:/, it cannot find them. I have tried 2 different floppies and neither one is working. Could it be a bad floppy drive in the desktop that I'm working on? Or is Windows just being a bitch?
I'm a noob at setting SATA raids. Basically all I want to do it get Windows installed on one of the SATA HDD's that I have connected to this PCI controller. Any help from some of you more experienced dude's would be greatly appreciated.
Q:
How to install a new windows installation to hard drive attached to the PSA150 SATA Raid card?
A:
STEP 1 Make sure to copy the Windows driver from the Driver CD on to a 1.44MB floppy diskette. You will need the driver in the 1.44MB floppy diskette during the installation.
(a) With Raid function: Copy the\Silicon_Image\SIL3x12RAID\Windows driver from the Driver CD to the diskette.
(b) Without Raid function: Copy the \Silicon_Image\SIL3x12\Windows driver from the Driver CD to the diskette.
STEP 2: Connect the HD to the PSA150 controller card and insert the card into PCI slot. Start up the system.
STEP 3: Boot up your Windows. Press "F6" for third party SCSI or driver installation at the beginning of the text mode installation. Insert the 1.44MB floppy diskette into the floppy drive. Press "S" when setup asks if you want to specify an additional device.
STEP 5: Press "ENTER" to continue on with text mode setup.
STEP 6: Follow the setup instructions to complete installling Windows.
