Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Lower is better... as long as your not getting read/write/wait errors.
Also if you happen to be sharing IRQ's and getting some problems from it... then higher PCI latency can help fix it.
Like I said thou lower is better. Stick with 32-64 and you should be fine. You can use PowerStrip to adjust your AGP and each PCI slots latency from within windows also.
