I recently bought a BFG 7900 GS OC for one of my home PC's and believe the existing power supply should be sufficient (Enermax NoiseTaker 485W... 2x12V @ 32A w/ a 6-pin PCI-Express power auxiliary power connector). Because i'm moving from an ATI card I wanted to test the new nVidia card in another machine here at work to make sure it's not DOA and before tearing into my own system and potentially getting into driver woes, etc.
The only machines I have at my disposal tho are HP dc7600 (P4 HT) and dc7700 (C2D E6300) towers. Both of these ship with a 365W power supply and are minimally optioned (CPU+memory+HDD+DVD), so there's not a whole lot of other devices consuming power. The specs list the PCI-Express slot as max. 75W and there's no additional 6-pin power connector. Factory video options are also limited to low power cards. Would it pose a risk to either the BFG card or power supply if I toss the BFG card into one of the HP's and use the power adapter supplied by BFG (2x4-pin power to 1x6-pin power)? I'm just looking to make sure it posts and do a bit of testing... maybe 3DMark and a demo or two.
Thanks.
Thanks.
