Hey folks,
I'm new to PCI-Express... just installed a new XFX 7800GT. My question is as follows -- The card has a male molex connector mounted on the board, which was a bit of a surprise since I had expected a PCI-Express power connector a-la the cable that came with my NeoPower 480. I figured it was just XFX makin my life easier, so I plugged in a standard molex connector straight onto the card and it seems to work fine. Now -- said connector was on a line with 3 connectors in total, and my Hitachi SATA drive was close enough to use another connector on the same line. Is that ok, or should I give the 7800 its own dedicated line? Its all running off the same rail anyway right?
Im still installin drivers and apps and such, so I haven't fired up Everquest yet to test it... So I figured I'd post here and get your expert advice before I fry the card.
Thanks!
Thanks!
