PCI Express != PCI-X ?? Sorta confusing, isn't it?
Parabellum
Hello,
Just wondering about those future PCI Express slot. Are the PCI-X slots the same or what? I just don't get it...
PCI-X are an extension of PCI. PCI-Express is a all new standard using serial communication.
PCI-X is a type of PCI express. There are several different flavors of PCI express depending upon the bandwidth required.
The following link is a great article on PCI express:
Anandtech
Anandtech
erm........
PCI-X and pci-express have nothing to do with eachother, other than both being higher bandwidth than PCI.
Originally posted by afirawker
PCI-X is what PCI ports are today. PCI-E is PCI express.
PCI-X is a 64 bit version of pci which is used mostly in servers/high end workstations. PCI-express it the replacement which is coming out for PCI slots in desktops. am i correct?
....no, no, no, no.....
PCI-X is a high speed extension of the PCI spec. You can plug a PCI card into a PCI-X slot and the slot will initialize and run just fine....or, at least it's supposed to according to the spec. You'll find 133 MHz 64 bit PCI-X slots and cards in many of the better servers out there.
PCI-E is new; PCI-E is as different from PCI as you can imagine. PCI-E is high speed, differentially signalled, serial connections. PCI / PCI-X....isn't.
PCI nor PCI-X cards will fit in a PCI-E slot unless you use a hammer and chainsaw.
....:D
B.B.S.
To add to this....
PCI-Express is slated to replace both regular PCI and AGP in desktop machines. Its said it may replace PCI-X as well at some point since it can already provide more bandwidth than PCI-X.
PCI-Express is a serialized arcitechture, and thus uses a smaller slot. A slot can have addtional "lanes" to increase bandwidth. However adding more "lanes" adds more wires which increases the size of the slot. A single "lane" slot is considered 1x.
PCI-E 1x slots can actually fit right in front of standard PCI slots on a motherboard. So you could fit 5 PCI-X 1x and 5 PCI slots in the same space :)
PCI-E 16x will replace AGP. With PCI-E 16x you have 5.8GB/sec of bandwidth available. (!!) AGP 8x provides only 2.1GB/sec.
PCI-E goes right up to 32x which provides 10GB/sec.
So you can't put regular PCI cards in PCI-E slots? That sucks.
Yes, just as much as it sucked when you couldn't put your fancy 16-bit ISA cards in those newfangled PCI slots, quite some years ago.
hahahahhaahahahhahaahahhahah very nice.
AJ
And we come full circle.
Well if you ever want to move forward you have to drop backwards compatibility at some point.
That said, PCI-Express and PCI-X are both software compatible to standard PCI. Just as SATA is software conpatible to standard ATA/IDE.
Yeah but people will have to buy new sound cards, tv cards, ethernet cards, all that.
Ah well, not much you can do.
It's not like PCI is dissapreaing overnight.
There is likely only going to be 2 PCI-E 16 slots in early BTX boards, the bulk of the i/o card slots will continue to be PCI for quite some time.
...nor will PCI-X. In the server space, there sure seems to be a lot more "hysteresis" than there is in the consumer / workstation space.
Like ISA and VESA cards before PCI / PCI-X and now PCI-E.....change is good....:D
Cheers - B.B.S.
