My PC has a PCI Express 2.0x16 slot in which I am running a XFX 9800GT, I want to replace it with a 7750 which is a PCI Express 3.0x16. Will this work? What will it cause in the form of trouble? Thanks Scott
So in saying this would you recommend this card or not? I do some gaming on the PC mostly XBOX, I want this card so I can send streaming video from my PC to a TV. Thanks ScottPCI-e 3.0 cards are backwards-compatible with PCI-e 2.0 slots. The card will simply run at PCI-e 2.0 bandwidth. However, the HD 7750 is not powerful enough to come anywhere close to saturating even PCI-e 2.0, let alone PCI-e 3.0.
Ok one more question and I'm done...I got to looking at the 2 cards ( my current 9800 GT and the 7750 ) the 9800 Gt has 512 MB RAM and 256-bit GDDR3, the 7750 has 1 GB RAM and 128-bit GDDR5. So my question is with higher RAM but lower bit am I gaining that much or just the ability to have a HDMI output?
As far as the bit rate is concerned, they're almost equal seeing that 256-bit is based on DD3 bandwidth, whereas 128-bit is based on DDR5.
